RG-DEMUX/MUX Series 24-Port/48-Port Combiner/Transparent Distribution Device
  • The 8-port 16-wavelength combiner innovatively adopts the colored optical technology and is used in combination with core or access switches equipped with pluggable colored optical transceivers.
  • The dual-slot design provides 24 ports for device access per slot and a maximum of 48 ports for device access at full load. The device uses six WDM optical fibers for output.
  • The passive network design supports direct replacement of distribution switches without requirement for O&M of ELV rooms.
  • Exclusive Gigabit/10G fiber to the room is supported and the bandwidth can be upgraded easily. Transparent distribution devices can be retained during the upgrade.
  • Multiple installation modes are available for selection.
Installation Modes
Solution Advantages
Topology Comparison
Exclusive bandwidth
Ease of Bandwidth Expansion
RG-DEMUX-24LC/LC
RG-DEMUX(C)-24LC/LC
RG-DEMUX-48LC/LC
RG-MUX-24LC/LC
RG-MUX(C)-24LC/LC
RG-MUX-48LC/LC
Name
48-port demultiplexer
3 groups
3 groups
6 groups
3 groups
3 groups
3 groups
Installation location
Core side
Core side
Core side
Building side
Building side
Building side
24
24
24
24
Dimension (W × D × H)
216.4 mm * 207 mm *33 mm
297.6 mm * 438.5 mm * 40.2 mm
216.4 mm * 207 mm * 33 mm
210.2 mm * 440 mm * 39.8 mm
RG-DEMUX(C)-24LC/LC
Center wavelength
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
Channel bandwidth
±6.5 nm
Insertion loss
Return loss
> 45 dB
Polarization dependent loss
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 35 dB
Connector
LC/UPC
-40°C to 85 °C
10% to 90% RH
5% to 90% RH
Standards
GR-1221-Core and GR-1209-Core
3.05 kg (net weight)
RG-MUX(C)-24LC/LC
24-port transparent multiplexer, with 3 demultiplexing ports (number of trunk fiber-optic cables can be connected)
Center wavelength
Channel spacing
20 nm
Channel bandwidth
±6.5 nm
Insertion loss
Return loss
> 45 dB
< 0.3 dB
> 25 dB
> 35 dB
Connector
LC/UPC
-40°C to 85 °C
10% to 90% RH
5% to 90% RH
Standards
2.57 kg (net weight)
